| Skip Navigation Links | |
| Exit Print View | |
Sun Ethernet Fabric Operating System RMON Administration Guide |
Enable the Ethernet Statistics Group
Disable the Ethernet Statistics Group
Configuring the Ethernet History Group
Enable the Ethernet History Group
The RMON Ethernet statistics group collects statistics for each monitored interface on the device and stores them in the Ethernet statistics table (etherStatsTable). This section contains procedures that explain how to enable or disable the Ethernet statistics group.
