| Skip Navigation Links | |
| Exit Print View | |
Sun Ethernet Fabric Operating System RMON Administration Guide |
Configuring the Ethernet Statistics Group
Enable the Ethernet Statistics Group
Disable the Ethernet Statistics Group
Configuring the Ethernet History Group
Enable the Ethernet History Group
This section contains procedures that explain how to configure the SEFOS RMON features. The procedures in this section are based on Topology Example. Before you can configure the RMON features, you must configure your network environment and enable the RMON module.
These sections show how to configure RMON:
