| Skip Navigation Links | |
| Exit Print View | |
Sun Storage 6 Gb SAS REM HBA Installation Guide For HBA Models SGX-SAS6-REM-Z and SG-SAS6-REM-Z |
Chapter 2 Hardware Installation and Removal
To Prepare for Hardware Installation
Validating the Solaris Labels of the HBA Logical Drives (Solaris OS)
To Verify That the Solaris Label of a Logical Drive Is Valid
Chapter 3 Creating a Bootable Drive in a Preboot Environment
![]() | Caution - Damage to the HBA can occur as the result of careless handling or e lectrostatic discharge (ESD). Always handle the HBA with care to avoid damage to electrostatic sensitive components. |
To minimize the possibility of ESD-related damage, use both a workstation antistatic mat and an ESD wrist strap. You can get an ESD wrist strap from any reputable electronics store or from Oracle as part number #250-1007.
Observe the following precautions to avoid ESD-related problems:
Leave the HBA in its antistatic bag until you are ready to install it in the system.
Always use a properly fitted and grounded wrist strap or other suitable ESD protection when handling the HBA and observe proper ESD grounding techniques.
Place the HBA on a properly grounded antistatic work surface pad when it is out of its protective antistatic bag.
