| Skip Navigation Links | |
| Exit Print View | |
Sun Storage 6 Gb SAS REM HBA Installation Guide For HBA Models SGX-SAS6-REM-Z and SG-SAS6-REM-Z |
Chapter 2 Hardware Installation and Removal
Observing ESD and Handling Precautions
Validating the Solaris Labels of the HBA Logical Drives (Solaris OS)
To Verify That the Solaris Label of a Logical Drive Is Valid
Chapter 3 Creating a Bootable Drive in a Preboot Environment
See HBA Features.
For optimal performance, use like drives (type, speed, and size) when creating logical drives. All of the disk drives must have the same performance level. You can use different-sized disk drives in the array, but the array will be limited to the capacity of the smallest and slowest disk drive.
For more information, refer to the MegaRAID SAS Software User's Guide at: http://www.lsi.com/sep/Pages/oracle/index.aspx
The HBA supports SAS disk drives and SATA II disk drives.
