Supported Versions of the OS, Firmware, and Software
Required OS Package and Patch Updates
Determining Oracle Solaris 11 OS Package Update Version
Identifying Drive Logical Device Names and Physical Locations
Correlate WWN Device Names With Physical Locations (diskinfo Command)
Oracle Solaris Jumpstart WWN Syntax
Interactive Installation Example
High-Altitude Mode Oracle ILOM Feature
Sun Type 6 Keyboards Are Not Supported by SPARC and Netra SPARC T4 Series Servers
Chassis CMM Does Not Allocate Enough Power to the Netra T4-1B Server Module (CR 7141886)
PSH Might Not Clear a Retired Cache Line on a Replaced Motherboard (CR 7031216)
2-Meter USB Cable Length Limit (7048419)
During a Reboot After an Unrecoverable Hardware Error, CPUs Might Not Start (CR 7075336)
Blue LED on Drive Does Not Light When the Drive Is Ready to Remove (CR 7082700)
Firmware, OS, and Other Software Issues
fault.memory.memlink-uc Fault Did Not Cause Panic as Stated by System Message (CR 6940599)
Timestamp for an Oracle ILOM Fault/Critical Event Might Be off by One Hour (CR 6943957)
sas2ircu Message That RAID Volume Sizes Other Than MAX Are Not Supported (CR 6983210)
Fault Management Sometimes Sends Resolved Cases to the SP (CR 6983432)
Units Used to Define the MIB Power Management Time Limit Are Reported in Seconds (CR 6993008)
Spurious Interrupt Message in System Console When Using Oracle VTS (CR 7038266)
Intermittent Link Training Timeout Displayed During Power Cycles (CR 7043201)
The cfgadm Command Might Fail on SG-SAS6-REM-Z or SGX-SAS6-REM-Z HBAs (CR 7044759)
Message From cpustat Refers to Processor Documentation Incorrectly (CR 7046898)
The reboot disk Command Occasionally Fails When disk Argument Picks Up Extra Characters (CR 7050975)
PCIe Correctable Errors Might Be Reported (CR 7051331)
Watchdog Timeouts Seen With Heavy Workloads and Maximum Memory Configurations (CR 7083001)
ereport.fm.fmd.module Generated During a Reboot of an SDIO Domain (CR 7085231)
Oracle VTS dtlbtest Hangs When CPU Threading Mode Is Set to max-ipc (CR 7094158)
If you have access to the OS, you might be able to use the diskinfo command instead. See Correlate WWN Device Names With Physical Locations (diskinfo Command).
{0} ok probe-scsi-all
/pci@400/pci@1/pci@0/pci@c/LSI,sas@0 <===== SAS Controller
FCode Version 1.00.54, MPT Version 2.00, Firmware Version 5.00.17.00
Target 9
Unit 0 Disk SEAGATE ST930003SSUN300G 0B70 585937500 Blocks, 300 GB
SASDeviceName 5000c50033438dbb SASAddress 5000c50033438db9 PhyNum 0 <=HD,slot 0
Target b
Unit 0 Disk SEAGATE ST930003SSUN300G 0468 585937500 Blocks, 300 GB
SASDeviceName 5000c50005c15803 SASAddress 5000c50005c15801 PhyNum 1 <=HD,slot 1
Target c
Unit 0 Encl Serv device SUN NEM Hydra II SOL 0308
SASAddress 5080020000bb193d PhyNum 24
/pci@400/pci@1/pci@0/pci@0/pci@0/usb@0,2/hub@3/storage@2
Unit 0 Removable Read Only device AMI Virtual CDROM 1.00LSI,sas@0 – Controller (REM) on the server module.
SASDeviceName – WWN that the Oracle Solaris OS recognizes.
SASAddress – WWN that the OBP references.
PhyNum – Physical slot that the drive occupies.
This example is based on the previous output:
cn = c0
where n is the SAS controller number, 0 in this example.
tn = t5000c50033438dbb
where n is the SASDeviceName value.
dn = d0
where n is 0 for all embedded SCSI devices.
The resulting logical device name is c0t5000c50033438dbbd0.
