Supported Versions of the OS, Firmware, and Software
Required OS Package and Patch Updates
Identifying Drive Logical Device Names and Physical Locations
Correlate WWN Device Names With Physical Locations (diskinfo Command)
Correlate WWN Device Names With Physical Locations (probe-scsi-all Command)
Oracle Solaris Jumpstart WWN Syntax
Interactive Installation Example
High-Altitude Mode Oracle ILOM Feature
Sun Type 6 Keyboards Are Not Supported by SPARC and Netra SPARC T4 Series Servers
Chassis CMM Does Not Allocate Enough Power to the Netra T4-1B Server Module (CR 7141886)
PSH Might Not Clear a Retired Cache Line on a Replaced Motherboard (CR 7031216)
2-Meter USB Cable Length Limit (7048419)
During a Reboot After an Unrecoverable Hardware Error, CPUs Might Not Start (CR 7075336)
Blue LED on Drive Does Not Light When the Drive Is Ready to Remove (CR 7082700)
Firmware, OS, and Other Software Issues
fault.memory.memlink-uc Fault Did Not Cause Panic as Stated by System Message (CR 6940599)
Timestamp for an Oracle ILOM Fault/Critical Event Might Be off by One Hour (CR 6943957)
sas2ircu Message That RAID Volume Sizes Other Than MAX Are Not Supported (CR 6983210)
Fault Management Sometimes Sends Resolved Cases to the SP (CR 6983432)
Units Used to Define the MIB Power Management Time Limit Are Reported in Seconds (CR 6993008)
Spurious Interrupt Message in System Console When Using Oracle VTS (CR 7038266)
Intermittent Link Training Timeout Displayed During Power Cycles (CR 7043201)
The cfgadm Command Might Fail on SG-SAS6-REM-Z or SGX-SAS6-REM-Z HBAs (CR 7044759)
Message From cpustat Refers to Processor Documentation Incorrectly (CR 7046898)
The reboot disk Command Occasionally Fails When disk Argument Picks Up Extra Characters (CR 7050975)
PCIe Correctable Errors Might Be Reported (CR 7051331)
Watchdog Timeouts Seen With Heavy Workloads and Maximum Memory Configurations (CR 7083001)
ereport.fm.fmd.module Generated During a Reboot of an SDIO Domain (CR 7085231)
Oracle VTS dtlbtest Hangs When CPU Threading Mode Is Set to max-ipc (CR 7094158)
Updates to Oracle Solaris 11 are provisioned using package updates called Support Repository Updates (SRUs) instead of patches. SRUs are part of a new OS provisioning scheme called the Image Packaging System (IPS).
To determine the package version of the Oracle Solaris 11 OS installed on your system, use the pkg info kernel command and interpret the FMRI value displayed in the output. This is an example:
# pkg info kernel
Summary: Core Kernel
Description: Core operating system kernel, device drivers and other modules.
Category: System/Core
State: Installed
Publisher: solaris
Version: 0.5.11
Build Release: 5.11
Branch: 0.175.0.2.0.2.1
Packaging Date: Wed Oct 19 07:57:11 2011
FMRI: pkg://solaris/system/kernel@0.5.11,5.11-0.175.0.2.0.2.1:
20111128T20503
Evaluate the following three fields in the FMRI value:
175 – The value 175 indicates that the system has Oracle Solaris 11 OS installed. This value is a constant for Oracle Solaris 11.
0 – The first field to the right of 175 indicates the update release. In this example, there have been no updates to the initial release.
2 – The next field contains the SRU value. In this example, the second patch bundle (called SRU2) has been installed on Oracle Solaris 11, update 0.
You can ignore the other fields in the FMRI package description.
When you know which version of the OS is installed, you can access a list of all the packages contained in that release from the following web page: http://pkg.oracle.com/solaris/release/en/index.shtml
To list the packages contained in a particular Oracle Solaris 11 release, select that release in the Release and Branch pull-down menu and press the Browse button. Or you can search for individual packages in the Search for: window.
