Supported Versions of the OS, Firmware, and Software
Required OS Package and Patch Updates
Determining Oracle Solaris 11 OS Package Update Version
Identifying Drive Logical Device Names and Physical Locations
Correlate WWN Device Names With Physical Locations (diskinfo Command)
Correlate WWN Device Names With Physical Locations (probe-scsi-all Command)
Oracle Solaris Jumpstart WWN Syntax
High-Altitude Mode Oracle ILOM Feature
Sun Type 6 Keyboards Are Not Supported by SPARC and Netra SPARC T4 Series Servers
Chassis CMM Does Not Allocate Enough Power to the Netra T4-1B Server Module (CR 7141886)
PSH Might Not Clear a Retired Cache Line on a Replaced Motherboard (CR 7031216)
2-Meter USB Cable Length Limit (7048419)
During a Reboot After an Unrecoverable Hardware Error, CPUs Might Not Start (CR 7075336)
Blue LED on Drive Does Not Light When the Drive Is Ready to Remove (CR 7082700)
Firmware, OS, and Other Software Issues
fault.memory.memlink-uc Fault Did Not Cause Panic as Stated by System Message (CR 6940599)
Timestamp for an Oracle ILOM Fault/Critical Event Might Be off by One Hour (CR 6943957)
sas2ircu Message That RAID Volume Sizes Other Than MAX Are Not Supported (CR 6983210)
Fault Management Sometimes Sends Resolved Cases to the SP (CR 6983432)
Units Used to Define the MIB Power Management Time Limit Are Reported in Seconds (CR 6993008)
Spurious Interrupt Message in System Console When Using Oracle VTS (CR 7038266)
Intermittent Link Training Timeout Displayed During Power Cycles (CR 7043201)
The cfgadm Command Might Fail on SG-SAS6-REM-Z or SGX-SAS6-REM-Z HBAs (CR 7044759)
Message From cpustat Refers to Processor Documentation Incorrectly (CR 7046898)
The reboot disk Command Occasionally Fails When disk Argument Picks Up Extra Characters (CR 7050975)
PCIe Correctable Errors Might Be Reported (CR 7051331)
Watchdog Timeouts Seen With Heavy Workloads and Maximum Memory Configurations (CR 7083001)
ereport.fm.fmd.module Generated During a Reboot of an SDIO Domain (CR 7085231)
Oracle VTS dtlbtest Hangs When CPU Threading Mode Is Set to max-ipc (CR 7094158)
In an interactive installation, you are asked to specify one or more drives as the targets for the OS installation. This step ensures that enough storage capacity is provided for the installation. For this step, specify the drive with the WWN value corresponds to the drive on which you want to install the software.
These WWN values are illustrated in the following interactive example. The drive selected as the installation target is located in drive slot 0, the default boot location.
Note - If you prefer to use some other disk, you can specify it instead of the one in HDD slot 0.
_ Select Disks_________________________________________________________________
On this screen you must select the disks for installing Solaris software. Start
by looking at the Suggested Minimum field; this value is the approximate space
needed to install the software you've selected. Keep selecting disks until the
Total Selected value exceeds the Suggested Minimum value.
NOTE: ** denotes current boot disk
Disk Device Available Space
[ ] c0t5000C50005C15803d0 286090 MB
[X] c0t5000C50033438DBBd0 286090 MB (F4 to edit)
Total Selected: 286090 MB
Suggested Minimum: 5032 MB
______________________________________________________________________________
Esc-2_Continue F3_Go Back F4_Edit F5_Exit F6_Help
Note - You might need to label new and replacement drives using the format utility before you can install the OS on the drives.
