Skip Navigation Links
Exit Print View
Netra SPARC T4-1B Server Module
Product Notes
search filter icon
search icon
Document Information
Using This Documentation
Related Documentation
Feedback
Support and Accessibility
Late-Breaking Information
Supported Chassis
Identify Your Chassis Version
Supported Hardware Components
Preinstalled Software
Supported Versions of the OS, Firmware, and Software
Required OS Package and Patch Updates
Determining Oracle Solaris 11 OS Package Update Version
Oracle Solaris 10 OS Patches
Identifying Drive Logical Device Names and Physical Locations
Correlate WWN Device Names With Physical Locations (diskinfo Command)
Correlate WWN Device Names With Physical Locations (probe-scsi-all Command)
Oracle Solaris Jumpstart WWN Syntax
Interactive Installation Example
High-Altitude Mode Oracle ILOM Feature
Known Product Issues
Hardware Issues
Sun Type 6 Keyboards Are Not Supported by SPARC and Netra SPARC T4 Series Servers
Chassis CMM Does Not Allocate Enough Power to the Netra T4-1B Server Module (CR 7141886)
PSH Might Not Clear a Retired Cache Line on a Replaced Motherboard (CR 7031216)
2-Meter USB Cable Length Limit (7048419)
Uncorrectable L2 Cache Errors Are Sometimes Reported as Core Faults Without any Cache Line Retirement (CR 7071237 and CR 7071974)
During a Reboot After an Unrecoverable Hardware Error, CPUs Might Not Start (CR 7075336)
Blue LED on Drive Does Not Light When the Drive Is Ready to Remove (CR 7082700)
Firmware, OS, and Other Software Issues
fault.memory.memlink-uc Fault Did Not Cause Panic as Stated by System Message (CR 6940599)
Timestamp for an Oracle ILOM Fault/Critical Event Might Be off by One Hour (CR 6943957)
e1000g Driver Generates Spurious ereports When Installing Oracle Solaris OS Over a Sun PCIe Dual Gigabit Ethernet Adapter (CR 6958011)
When diag-switch? is Set to true, Oracle Solaris OS Fails to Update the EEPROM for Automatic Rebooting (CR 6982060)
sas2ircu Message That RAID Volume Sizes Other Than MAX Are Not Supported (CR 6983210)
Fault Management Sometimes Sends Resolved Cases to the SP (CR 6983432)
Units Used to Define the MIB Power Management Time Limit Are Reported in Seconds (CR 6993008)
Spurious Interrupt Message in System Console When Using Oracle VTS (CR 7038266)
Intermittent Link Training Timeout Displayed During Power Cycles (CR 7043201)
The cfgadm Command Might Fail on SG-SAS6-REM-Z or SGX-SAS6-REM-Z HBAs (CR 7044759)
Message From cpustat Refers to Processor Documentation Incorrectly (CR 7046898)
The reboot disk Command Occasionally Fails When disk Argument Picks Up Extra Characters (CR 7050975)
PCIe Correctable Errors Might Be Reported (CR 7051331)
Watchdog Timeouts Seen With Heavy Workloads and Maximum Memory Configurations (CR 7083001)
ereport.fm.fmd.module Generated During a Reboot of an SDIO Domain (CR 7085231)
Oracle VTS dtlbtest Hangs When CPU Threading Mode Is Set to max-ipc (CR 7094158)
Documentation Issues
The cfgadm command might fail on SG-SAS6-REM-Z or SGX-SAS6-REM-Z HBA devices.
# cfgadm -c unconfigure Slot1
cfgadm: Component system is busy, try again: unconfigure failed
WARNING: (pcieb2): failed to detach driver for the device (mpt_sas9) in the Connection Slot1
Workaround: Disable the fault management daemon before running the cfgadm unconfigure command.
# svcadm disable fmd
# ps -ef |grep fmd
# cfgadm -c unconfigure PCI-EM0
After completing the cfadm task, re-enable the fault management daemon.
# svcadm enable fmd
