Supported Versions of the OS, Firmware, and Software
Required OS Package and Patch Updates
Determining Oracle Solaris 11 OS Package Update Version
Identifying Drive Logical Device Names and Physical Locations
Correlate WWN Device Names With Physical Locations (diskinfo Command)
Correlate WWN Device Names With Physical Locations (probe-scsi-all Command)
Oracle Solaris Jumpstart WWN Syntax
Interactive Installation Example
High-Altitude Mode Oracle ILOM Feature
Sun Type 6 Keyboards Are Not Supported by SPARC and Netra SPARC T4 Series Servers
Chassis CMM Does Not Allocate Enough Power to the Netra T4-1B Server Module (CR 7141886)
PSH Might Not Clear a Retired Cache Line on a Replaced Motherboard (CR 7031216)
2-Meter USB Cable Length Limit (7048419)
During a Reboot After an Unrecoverable Hardware Error, CPUs Might Not Start (CR 7075336)
Blue LED on Drive Does Not Light When the Drive Is Ready to Remove (CR 7082700)
Firmware, OS, and Other Software Issues
fault.memory.memlink-uc Fault Did Not Cause Panic as Stated by System Message (CR 6940599)
Timestamp for an Oracle ILOM Fault/Critical Event Might Be off by One Hour (CR 6943957)
sas2ircu Message That RAID Volume Sizes Other Than MAX Are Not Supported (CR 6983210)
Fault Management Sometimes Sends Resolved Cases to the SP (CR 6983432)
Units Used to Define the MIB Power Management Time Limit Are Reported in Seconds (CR 6993008)
Spurious Interrupt Message in System Console When Using Oracle VTS (CR 7038266)
Intermittent Link Training Timeout Displayed During Power Cycles (CR 7043201)
The cfgadm Command Might Fail on SG-SAS6-REM-Z or SGX-SAS6-REM-Z HBAs (CR 7044759)
Message From cpustat Refers to Processor Documentation Incorrectly (CR 7046898)
The reboot disk Command Occasionally Fails When disk Argument Picks Up Extra Characters (CR 7050975)
PCIe Correctable Errors Might Be Reported (CR 7051331)
ereport.fm.fmd.module Generated During a Reboot of an SDIO Domain (CR 7085231)
Oracle VTS dtlbtest Hangs When CPU Threading Mode Is Set to max-ipc (CR 7094158)
With certain unusual heavy workloads, especially where a highly processor-intensive workload is bound to CPU 0, the host might appear to suddenly reset back to OBP without any sign of there having been a crash or a panic. The Oracle ILOM event log contains a host watchdog expired entry. The problem is more likely to occur on systems with full memory configurations.
If you see this sort of sudden reset, display the SP event log using this command from the Oracle ILOM CLI:
-> show /SP/logs/event/list
If you see an entry labeled Host watchdog expired, you are experiencing this issue.
Workaround: Contact your authorized service provider to see if a fix is available.
There are two ways you can work around this issue:
You can extend the watchdog period by adding this entry to the Oracle Solaris /etc/system file:
set watchdog_timeout = 60000
This extends the watchdog timeout period to 1 minute (60000 milliseconds).
In extreme cases, you can disable the watchdog timeout altogether by adding this entry to the /etc/system file:
set watchdog_enabled = 0
Whenever you modify the /etc/system file you must reboot the system for the changes to take effect.
If you do not want to reboot the system immediately after editing /etc/system, you can apply an additional temporary workaround that takes effect immediately. To apply this temporary workaround, as root type.
# psrset -c -F 0
This command creates a temporary processor set containing only CPU 0, preventing application workloads from using this processor and preventing this issue from occurring.
Note - If any threads were bound to CPU 0, they will be unbound.
This temporary processor set is removed on the next operating system reboot, at which point the /etc/system file workaround takes effect.
