Supported Versions of the OS, Firmware, and Software
Required OS Package and Patch Updates
Determining Oracle Solaris 11 OS Package Update Version
Identifying Drive Logical Device Names and Physical Locations
Correlate WWN Device Names With Physical Locations (diskinfo Command)
Correlate WWN Device Names With Physical Locations (probe-scsi-all Command)
Oracle Solaris Jumpstart WWN Syntax
Interactive Installation Example
High-Altitude Mode Oracle ILOM Feature
Sun Type 6 Keyboards Are Not Supported by SPARC and Netra SPARC T4 Series Servers
Chassis CMM Does Not Allocate Enough Power to the Netra T4-1B Server Module (CR 7141886)
PSH Might Not Clear a Retired Cache Line on a Replaced Motherboard (CR 7031216)
During a Reboot After an Unrecoverable Hardware Error, CPUs Might Not Start (CR 7075336)
Blue LED on Drive Does Not Light When the Drive Is Ready to Remove (CR 7082700)
Firmware, OS, and Other Software Issues
fault.memory.memlink-uc Fault Did Not Cause Panic as Stated by System Message (CR 6940599)
Timestamp for an Oracle ILOM Fault/Critical Event Might Be off by One Hour (CR 6943957)
sas2ircu Message That RAID Volume Sizes Other Than MAX Are Not Supported (CR 6983210)
Fault Management Sometimes Sends Resolved Cases to the SP (CR 6983432)
Units Used to Define the MIB Power Management Time Limit Are Reported in Seconds (CR 6993008)
Spurious Interrupt Message in System Console When Using Oracle VTS (CR 7038266)
Intermittent Link Training Timeout Displayed During Power Cycles (CR 7043201)
The cfgadm Command Might Fail on SG-SAS6-REM-Z or SGX-SAS6-REM-Z HBAs (CR 7044759)
Message From cpustat Refers to Processor Documentation Incorrectly (CR 7046898)
The reboot disk Command Occasionally Fails When disk Argument Picks Up Extra Characters (CR 7050975)
PCIe Correctable Errors Might Be Reported (CR 7051331)
Watchdog Timeouts Seen With Heavy Workloads and Maximum Memory Configurations (CR 7083001)
ereport.fm.fmd.module Generated During a Reboot of an SDIO Domain (CR 7085231)
Oracle VTS dtlbtest Hangs When CPU Threading Mode Is Set to max-ipc (CR 7094158)
The server module has three USB ports:
Port 1 and 2, accessible through a dongle that is attached to the front UCP connector.
Port 5, located on the rear of the motherboard (intended for a USB flash drive).
Workaround: If you connect USB devices to ports 1 or 2, ensure that the cable does not exceed 2 meters (approximately 6.5 feet).
