Rack units |
5U |
5U |
Height |
8.5 in. |
215 mm |
Width |
17.5 in. |
445 mm |
Depth |
31.5 in. |
800 mm |
Weight (without rackmount kit) |
Fully populated (two processor modules) |
166 lb |
75.4 kg |
Half populated (one procesor module
and one processor filler module) |
154.675 lb |
70.24 kg |
Minimum service clearance (front) |
36 in. |
914.4 mm |
Minimum service clearance (rear) |
36 in. |
914.4 mm |
Minimum airflow clearance (front) |
2 in. |
50.8 mm |
Minimum airflow clearance (rear) |
3 in. |
76.2 mm |
