VGA Port
The server has two 15-pin VGA video ports, one port on the front and one on the back of the
server. See Front Panel
Components and Rear Panel Components. Use a HD-15 video cable to connect to a video
adapter to achieve the required connection.
Note - Only one of the two ports can be used at a time. The
rear VGA port is disabled by default. To enable the rear port and
disable the front port, you must enable the Oracle ILOM VGA_REAR_PORT policy: -> set /SP/policy VGA_REAR_PORT=enabled.
Note - The cable length used to connect between the monitor
and the VGA port should not be over 6 meters.
1 |
Red Video |
9 |
[KEY] |
2 |
Green Video |
10 |
Sync Ground |
3 |
Blue Video |
11 |
Monitor ID - Bit 1 |
4 |
Monitor ID - Bit 2 |
12 |
VGA 12C Serial Data |
5 |
Ground |
13 |
Horizontal Sync |
6 |
Red Ground |
14 |
Vertical Sync |
7 |
Green Ground |
15 |
VGA 12C Serial Clock |
8 |
Blue Ground |
