NET MGT
Port
The NET MGT RJ-45 port, located on the rear panel, provides
an optional Ethernet connection to the SP. The NET MGT port is an
optional connection to the Oracle ILOM SP. The SP NET MGT port uses
an RJ-45 cable for a 10/100BASE-T connection. If your network does
not use a DHCP server, this port will not be available until you configure
network settings through the SER MGT port. See Rear Panel Components.
1 |
Transmit Data + |
5 |
Common Mode Termination |
2 |
Transmit Data – |
6 |
Receive Data – |
3 |
Receive Data + |
7 |
4 |
8 |
