Electrical
Specifications
Use these specifications only as a general planning guide.
To determine power values based on expected workloads, use theSPARC T5-4 power
calculator located at this online site:
http://www.oracle.com/goto/powercalculators/
Operating input range |
200 to 240 VAC,
50-60 Hz |
Maximum operating input current at 200
VAC
(Actual amperage draw may exceed rating by no more than 10%) |
15.3 A
Maximum operating input power at 200
VAC
(Actual power draw may exceed rating by no more than 10%) |
3000W |
Maximum heat dissipation |
11,233 BTU/hr
11,851 KJ/hr |
Maximum standby power |
140W |
Maximum server configuration specification
under nominal temperature and voltage conditions:
(Four 3.6GHz T5 Processors, with sixty-four 32GB DDR3 DIMMS,
8 HDD and 16 I/O cards) |
Idle input power |
1495 W |
Peak AC input power (running SpecJBB) |
3292 W |
Minimum server configuration specification
(Two 3.6GHz T5 Processors, with 32x 16GB DDR3 DIMMS,
no HDD and no I/O cards) |
Idle input power |
678 W |
1480 W |
Note - The maximum operating input current values are based
on the formula
P / (V *0.90), where P = maximum operating input power and V = input
voltage. For example: 620W / (100V * 0.90) = 6.89A You can use this
formula to calculate the maximum operating current at your input
voltage.
 | Caution - Use only the power cords provided
with the server. |
