Front and
Rear Panel Components
1 |
Locator LED (white, also functions as
the physical presence switch) |
2 |
Ready to Remove LED (blue) |
3 |
Fault LED (amber) |
4 |
OK LED (green) |
5 |
Power button |
6 |
Reset button: NMI (for service use only) |
7 |
Drive Ready to Remove LED (blue) |
8 |
Drive Fault LED (amber) |
9 |
Drive OK LED (green) |
10 |
Ejector arm latch |
11 |
RFID tag (provides the serial number
of the server module) |
12 |
Top cover release button |
13 |
UCP |
14 |
Drive slots |
15 |
Rear chassis power connector |
16 |
Rear chassis data connection |
Refer to Server Module Service, Interpreting
LEDs, for more information about the LEDs.
