Language |
Select from the list of
available languages for the OS. |
English* |
Locale |
Select your geographic region
from the list of available locales. |
Terminal |
Select the type of terminal
that you are using from the list of available terminal types. |
Network connection |
Is the system connected
to a network? |
DHCP |
Can the system use Dynamic
Host Configuration Protocol (DHCP) to configure its network interfaces? |
If you are
not using DHCP, note the network address |
IP address |
Supply the IP address for
the system.
Example: 192.168.100.1 |
Subnet |
Is the system part of a
subnet?
If yes, what is the netmask of the subnet?
Example: 255.255.255.0 |
255.255.0.0* |
IPv6 |
Do you want to enable IPv6
on this machine? |
Host name |
Choose a host name for the
system. |
Kerberos |
Do you want to configure
Kerberos security on this machine?
If yes, gather this information:
Default realm:
Administration server:
First KDC:
(Optional) Additional KDCs: |
Name service |
Name service |
If applicable, which name
service will this system use? |
Domain name |
Provide the name of the
domain in which the system resides. |
DNS or NIS |
NIS+ and NIS |
If you chose NIS+
or NIS, do you want to specify a name server, or let
the installation program find one? |
If you choose NIS:
DNS |
If you chose DNS,
provide IP addresses for the DNS server. You must enter at least
one IP address, but you can enter up to three addresses.
You can also enter a list of DNS domains to search when a
DNS query is made.
Search domain:
Search domain:
Search domain: |
LDAP |
If you chose LDAP,
provide this information about your LDAP profile:
Profile name:
Profile server:
If you specify a proxy credential level in your LDAP profile,
Proxy-bind distinguished name:
Proxy-bind password: |
Default route |
Do you want to specify a
default route IP address, or let the OS installation program find
one?
The default route provides a bridge that forwards traffic
between two physical networks. An IP address is a unique number
that identifies each host on a network.
You have these choices:
You can specify the IP address. An /etc/defaultrouter file
is created with the specified IP address. When the system is rebooted,
the specified IP address becomes the default route.
You can let the OS installation program detect an
IP address. However, the system must be on a subnet that has a router
that advertises itself by using the ICMP for router discovery. If
you are using the CLI, the software detects an IP address when the
system is booted.
You can select None if you do not have a router
or do not want the software to detect an IP address at this time.
The software automatically tries to detect an IP address on reboot.
Specify
one
Detect One
None*
Time zone |
How do you want to specify
your default time zone? |
Geographic
region*
Offset from GMT
Time zone file
Root password |
Choose a root password for the system. |
