/etc/ppp/peers/myisp.tmpl Template
File
The /etc/ppp/peers/myisp.tmpl file contains helpful comments about
the /etc/ppp/peers/peer-name file. The template
concludes with common options that you might use for an
/etc/ppp/peers/peer-name file:
connect "/usr/bin/chat -f /etc/ppp/myisp-chat"
user myname
remotename myisp
noauth
noipdefault
defaultroute
updetach
noccp
| Call the peer by using the chat script /etc/ppp/myisp-chat.
user myname
| Use this account name for the local machine. myname is
the name for this machine in the peer's /etc/ppp/pap-secrets file.
remotename myisp
| Recognize myisp as the name of the peer in
the local machine's /etc/ppp/pap-secrets file.
noauth
| Do not require calling peers to provide authentication credentials.
noipdefault
| Do not use a default IP address for the local machine.
defaultroute
| Use the default route that is assigned to the local machine.
updetach
| Log errors in the PPP log files, rather than on the standard
output.
noccp
| Do not use CCP compression.
To use /etc/ppp/peers/myisp.tmpl at your
site, rename /etc/ppp/peers/myisp.tmpl to /etc/ppp/peers/.peer-name. Replace peer-name with the name of the peer to be called. Then
modify the file contents as needed by your site.
