The Patches and Updates screen appears.
The screen appears with search fields.
Alternatively, type a full or partial product name (for example, Sun Server X4-4) until a match appears.
The patches available for downloading are listed.
See Available Software Release Packages for a description of the available downloads.
A pop-up action panel appears. The pop-up panel contains several action options, including the Add to Plan and Download options. For information about the Add to Plan option, click on the associated drop-down button and select “Why use a plan?”
The File Download dialog box appears.
The patch file downloads.
