Go to main content
Oracle® Exadata Storage Server X5-2 High Capacity Service Manual
Exit Print View
Updated: January 2018
USB Ports
The server has six USB ports for attaching supported USB 2.0–compliant devices. Two USB ports are on the rear panel, two USB ports are on the front panel, and two USB ports are located on the motherboard.
image:Figure showing a USB port. Table 16  USB Port Signals
Pin
Signal Description
1
+5 V
2
DAT-
3
DAT+
4
Ground
Related Information
