Go to main content
Oracle I/O Domain Administration Guide
Exit Print View
Updated: August 2019
Domain Requirements
Before creating a domain, the system administrator must ensure that these requirements are met:
  • Oracle personnel completed the initial software installation, configuration, and created Root Domains as specified in your configuration worksheets.
    Refer to the Oracle SuperCluster T5-8 Owner’s Guide, the Overview Guide for your model (for example, Oracle SuperCluster M8 and SuperCluster M7 Overview Guide), and your configuration worksheets.
  • (Only applicable for SuperCluster version 2.6 or earlier) The CPU and memory resources for a dedicated domain are configured as needed using the osc-setcoremem tool. After the domains are created, you cannot change resources using the osc-setcoremem tool.
  • The Oracle SuperCluster Virtual Assistant must be available on SuperCluster. See Check the SuperCluster Virtual Assistant Version.
  • To initialize the assistant, you must have access to the XML file that describes the configuration of your system. Obtain the name and location of this file from your Oracle representative.
  • You must provide additional IP addresses for the domains. See Minimum Number of IP and Alt MAC Addresses.
  • Your browser must support secure SSL protocols (TLS version 1.2. or higher). Ensure that you are using the latest version of your browser.
Additional required information is needed for each I/O Domain that is created. For those details, see Required Information for Configuring I/O Domains.
Related Information
