Go to main content
Oracle I/O Domain Administration Guide
Exit Print View
Updated: August 2019
Upload an OVM Template (Deprecated)
As of SuperCluster version 3.0, this feature is no longer available. The following procedure applies to SuperCluster version 2.6 or earlier.
Oracle VM (OVM) templates enable you to deploy a fully configured software stack using preinstalled and preconfigured software images.
Before you can create domains using an OVM template, you must upload the template into the assistant. After the template is available, users can select the template during the domain creation process, which results in domains with a preconfigured OS and application. The templates in the assistant can be used repeatedly to create domains.
Only users with the administrator role can perform this procedure.
This table provides additional OVM template resources.
Resource
Link
Procedure in this guide
MOS article: Using OVM Templates in IO Domains on SuperCluster (Doc ID 2065199.1)
  1. Obtain an OVM template that is supported by the assistant.
    For more information about OVM templates, go to: http://www.oracle.com/technetwork/server-storage/vm/templates-101937.html
    Note -  Not all OVM templates are supported by the SuperCluster Virtual Assistant.
    Save the template in a location that is accessible as a file from the master control domain of SuperCluster.
  2. Access the SuperCluster Virtual Assistant.
    See Log In to the SuperCluster Virtual Assistant.
  3. In the navigation panel, select OVM Templates.
    image:A screen shot showing the OVM Template screen.
  4. In the Path to OVM Template, type the path to the OVM template that you downloaded from Oracle Support.
  5. Click Add Template.
    The template requires several minutes to upload. After the template is uploaded, you can create domains using the template.
  6. To monitor the upload progress, perform these activities:
    • In the assistant, watch for a message similar to this example:
      The template from file file:///var/tmp/ovmt/OVM_S11.3_WLS12.1.3_SPARC_SCRIPT_B4.ova is being added. This may take several minutes.
    • In the master control domain, type:
      root@etc4m-appadm0101:~# ps -ef | grep ovm | grep -v grep
      root 47826 47825   0 19:15:36 ?   0:00 ksh /opt/oracle.supercluster/osc-ovmt/osc-ovmt -i file:///var/tmp/ovmt/OVM_S11.
      root 47822   646   0 19:15:36 ?   0:00 /usr/bin/python /opt/oracle.supercluster/osc-domcreate/iodine/iodine/ovmt.py -a
      root 47914 47826   0 19:15:38 ?   0:00 /opt/oracle.supercluster/osc-ovmtutils/ovmtlibrary -c store -o file:///var/tmp
  7. Consider your next action.
