Go to main content
Oracle I/O Domain Administration Guide
Exit Print View
Updated: August 2019
Minimum Number of IP and Alt MAC Addresses
This table lists the minimum number of IP addresses you need for each I/O Domain. You can configure more than the minimum. You or your network administrator provide the IP addresses, and the assistant enables you to add and remove networks as needed. See Managing Resources and Networks.
Database
I/O Domain
Application
I/O Domain
Management network IP addresses
1
1
10GbE Client network IP addresses
1
1
10GbE SCAN IP addresses
Note -  If you create a RAC, no additional SCAN IPs are required.
3
10GbE VIP IP addresses
1
Storage IB network IP addresses
1
1
Exadata IB network IP addresses
1
Versaboot network IP addresses
2
2
The utility automatically assigns two alternate MAC addresses per core in each domain. If you plan to create zones in the domain, multiply the number of cores by two to determine the number of MAC addresses available for zones. If you increase the number of cores in a domain, you can increase the number of alternate MAC addresses. For details, refer to the My Oracle Support knowledge article ID 2198060.1 at http://support.oracle.com.
Related Information
