Go to main content
Oracle I/O Domain Administration Guide
Exit Print View
Updated: August 2019
Edit a Recipe
Use this procedure to edit a resource or network recipe. Any changes you make to a recipe are only reflected in future domains that are created using this recipe. The changes are not reflected in domains that are previously created based on the recipe.
Note -  The SuperCluster Virtual Assistant does not prevent you from creating a recipe that exceeds the total available resources. To view resources, see View System Resources.
  1. Access the SuperCluster Virtual Assistant.
    See Log In to the SuperCluster Virtual Assistant.
  2. In the navigation panel, select Recipes.
  3. Select the recipe you want to edit and click Edit.
  4. Change any of the displayed parameters.
  5. Click Save.
  6. Consider your next action.
