Go to main content
Oracle I/O Domain Administration Guide
Exit Print View
Updated: August 2019
Change a User's Password (Administrators)
Users with the administrator role can change any user's password.
Users without the administrator role can only change their own password (see Change Your Password)
Password parameters such as strength, are governed by the assistant's security settings. See Configure Security Settings (Administrators)
If a user forgets the password, a user with the administrator role can either initiate a password reset (see Reset a User's Password (Administrators)) or change the user's password as described in this procedure.
Note -  User passwords are initially set when the user account is created. See Add a User (Administrators).
  1. Log in to the assistant.
    See Log In to the SuperCluster Virtual Assistant.
  2. In the navigation panel, select Users and Allowances.
  3. Select the user whose password you want to change.
  4. Click Change Password.
    image:A screen shot showing the Edit User screen.
  5. Type the new password and password confirmation.
  6. Click Save.
  7. Consider your next action.
