Go to main content
Oracle I/O Domain Administration Guide
Exit Print View
Updated: August 2019
Domain Storage Resources
When you configure an domain, iSCSI LUN resources are automatically allocated. The assistant starts with a predefined amount of storage, then calculates additional resources for swap and dump based on the chosen CPU and memory resources.
If you deploy a domain using an OVM template, the template determines the amount of allocated iSCSI LUN resources.
For non OVM template-based Domains, the assistant approximately allocates these rpool resources, based on the type of domain and the version of the assistant:
Assistant Version
Database Domains
Application Domains
Branch 2.1.0.813 (or later)
150 GB
100 GB
Branches prior to 2.1.0.813
70 GB
50 GB
Tip  -  To determine the assistant version, see Check the SuperCluster Virtual Assistant Version.
Related Information
