By default, the TLSv1.0, TLSv1.1, and TLSv1.2 protocols are enabled for the HTTPS service.
You can disable one or more TLS protocol versions that do not comply with your security policies.
For security purposes, use TLSv1.2 unless support for older versions of the TLS protocol is required.
-> show /SP/services/https tlsv1 tlsv1_1 tlsv1_2 /SP/services/https Properties: tlsv1 = enabled tlsv1_1 = enabled tlsv1_2 = enabled
-> set /SP/services/https tlsv1_0=disabled
-> set /SP/services/https tlsv1_1=disabled
