Disable SSL Weak and Medium-Strength Ciphers for HTTPS
By default, Oracle ILOM disables the use of weak and medium-strength ciphers
for the HTTPS service.
On the management network, log in to Oracle ILOM.
See Log in to the Oracle ILOM CLI.
Determine if weak and medium-strength ciphers are disabled.
-> show /SP/services/https weak_ciphers
/SP/services/https
Properties:
weak_ciphers = disabled
If the default has been changed, you can disable the use of weak and
medium-strength ciphers.
-> set /SP/services/https weak_ciphers=disabled
Verify the setting by repeating Step 2.
