Oracle ILOM uses self-signed certificates to enable the out-of-the-box use of the SSL and TLS protocols. Whenever possible, replace self-signed certificates with certificates that are approved for use in your environment and signed by a recognized certificate authority.
Oracle ILOM supports a variety of methods that can be used to access the digital certificate and private key, including HTTPS, HTTP, SCP, FTP, TFTP, and pasting the information directly into a web browser interface. For more information, refer to the Oracle ILOM Configuration and Maintenance Guide (see Additional Oracle ILOM Resources).
-> show /SP/services/https/ssl cert_status /SP/services/https/ssl Properties: cert_status = Using Default (No custom certificate or private key loaded)
-> set /SP/services/https/ssl/custom_cert load_uri=URI_method -> set /SP/services/https/ssl/custom_key load_uri=URI_method
