By default, MLDS is disabled globally. To enable MLDS, you must first disable GMRP.
SEFOS# configure terminal SEFOS(config)# set gmrp disable
SEFOS(config)# ipv6 mld snooping SEFOS(config)# end
SEFOS# show ipv6 mld snooping globals Snooping Configuration ----------------------------- MLD Snooping globally enabled MLD Snooping is operationally enabled Transmit Query on Topology Change globally disabled Multicast forwarding mode is MAC based Proxy globally disabled Proxy reporting globally enabled Filter is disabled Router port purge interval is 125 seconds Port purge interval is 260 seconds Report forward interval is 5 seconds Group specific query interval is 2 seconds Reports are forwarded on router ports Group specific query retry count is 2 Multicast VLAN disabled Leave config level is Vlan based
SEFOS# show ipv6 mld snooping forwarding-database
Vlan MAC-Address Ports
2 33:33:00:01:00:01 Ex0/1
