When MLDS is enabled globally, it is enabled in all the existing VLAN interfaces. When MLD snooping is disabled globally, it is disabled in all the existing VLAN interfaces. However, you can enable MLDS on specific VLANs, as described in the following example.
In this example, MLDS is enabled on VLAN 2.
SEFOS# configure terminal SEFOS(config)# vlan 2
SEFOS(config-vlan)# ipv6 mld snooping SEFOS(config-vlan)# end
SEFOS# show ipv6 mld snooping vlan 2 Snooping VLAN Configuration for the VLAN 2 MLD Snooping enabled MLD Operating version is V2 Fast leave is disabled Snooping switch is acting as Non-Querier Query interval is 125 seconds
When MLDS is globally enabled or disabled, but not enabled on VLAN 2, the second line in the output of this command is:
MLD Snooping disabled
