The default for this feature is 260 seconds. In this example, the port-purge interval is 130 seconds.
SEFOS# configure terminal SEFOS(config)# ipv6 mld snooping port-purge-interval 130 SEFOS(config)# end
If an entry is learned on the forwarding database, after an interval of 130 seconds, the entry is removed from the forwarding database.
SEFOS# show ipv6 mld snooping globals Snooping Configuration ----------------------------- MLD Snooping globally enabled MLD Snooping is operationally enabled Multicast forwarding mode is MAC based Proxy reporting globally enabled Router port purge interval is 125 seconds Port purge interval is 130 seconds Report forward interval is 5 seconds Group specific query interval is 2 seconds Reports are forwarded on router ports Group specific query retry count is 2
The following output is displayed prior to the configuration of the port-purge interval.
SEFOS# show ipv6 mld snooping forwarding-database
Vlan MAC-Address Ports
4 33:33:00:01:00:01 Ex0/1
After 130 seconds, the output will be null. Executing the show command in this manner generates no output.
