The snooping multicast forwarding mode can be IP-based or MAC-based. By default, multicast forwarding mode is MAC based. In this example, the snooping multicast forwarding mode is IP.
SEFOS# configure terminal SEFOS(config)# snooping multicast-forwarding-mode ip SEFOS(config)# end
SEFOS# show ipv6 mld snooping globals Snooping Configuration ----------------------------- MLD Snooping globally disabled MLD Snooping is operationally disabled Multicast forwarding mode is IP based Proxy reporting globally enabled Router port purge interval is 125 seconds Port purge interval is 260 seconds Report forward interval is 5 seconds Group specific query interval is 2 seconds Reports are forwarded on router ports Group specific query retry count is 2
