The ipv6 mld snooping mrouter command statically configures the router ports for a specified VLAN.
In this example, VLAN 4 is the VLAN for which the snooping version is configured, and the multicast router ports are 0/4 and 0/5.
SEFOS# configure terminal SEFOS(config)# vlan 4 SEFOS(config-vlan)# ipv6 mld snooping mrouter extreme-ethernet 0/4 SEFOS(config-vlan)# ipv6 mld snooping mrouter extreme-ethernet 0/5
SEFOS# show ipv6 mld snooping mrouter Vlan Ports ----- ------ 4 Ex0/4(static), Ex0/5(static)
Vlan Ports
4 Ex0/2(dynamic), Ex0/4(static), Ex0/5(static)
Note that router ports will also be learned when they receive a PIM/OSPF message from a router.
