Verify Operation of Slide Rails
and CMA
Note - Two people are recommended for this procedure,
one to move the server in and out of the rack, and one to observe
the cables and CMA.
- Slowly
pull the server out of the rack until the slide rails reach their
stops.
- Inspect the attached cables for
any binding or kinks.
- Verify that the CMA extends fully
from the slide rails.
- Push the server back into the
rack.
When the server is fully extended, you must release two sets
of slide rail stops to return the server to the rack.
- Find and touch the first set of stops, which are levers located on the inside of each slide rail, just
behind the rear panel of the server.
Push in both green levers
simultaneously and slide the server toward the rack.
The server slides in approximately 18 inches (46 cm) and
stop.
Verify that the cables and the CMA retract without binding
before you continue.
- Find and touch the second set of stops, which are the
slide rail release buttons located near the front of each mounting
bracket.
Simultaneously push both of the green slide rail release
buttons, and push the server completely into the rack until both slide
rail locks engage.
- Adjust the cable straps and CMA,
as required.
