Two USB 2.0 ports can be accessed from the front of the server. See the location of the USB ports at Front Panel Components With Eight-Drive Backplane (Installation). The USB ports support hot-plugging. You can connect and disconnect USB cables and peripheral devices while the server is running, without affecting server operations.
Each USB 2.0 port supplies 5V output at 500 mA.
