Server Overview
This topic provides a high-level introduction to the main
components and capabilities of the server.
Chassis |
Rack-mountable server. |
CPU |
Two processors installed on the motherboard assembly. |
Memory |
Sixteen DDR4 DIMMs connect to the motherboard. A server with 16 64-GB DIMMs supports 1024 GB
of system memory.
I/O expansion |
Seven PCIe Gen3 slots. Six slots are in the rear and one for drive support is internal. All
slots support x8 PCIe cards. |
Storage devices |
For internal storage, the server provides several configurations, depending on the type of
drive backplane:
Eight 2.5-inch SAS drives. Four slots can use
2.5-inch NVMe drives.
Twelve 3.5-inch SAS drives, plus two 2.5-inch SAS drives in the rear, above the power
supplies.
Twenty four 2.5-inch SAS drives, plus two 2.5-inch drives
in the rear, above the power supplies.
Twelve 2.5-inch NVMe drives.
USB ports |
Two external USB 2.0 ports (front panel). |
Ethernet ports |
Four 10GbE 100/1000/10000 Mbps, RJ-45-based
ports on the rear panel. |
Power supplies |
Two hot-swappable (1+1) AC 1100W power supplies. |
Cooling fans |
Four hot-swappable, redundant fan modules at chassis front (top-loading).
Redundant fans in each power supply. |
SP |
Built into motherboard. Includes Oracle Integrated Lights Out Manager
(Oracle ILOM). |
