-> start /HOST/console [-option] Are you sure you want to start /HOST/console (y/n) ? y Serial console started. To stop, type #. . . .
where option can be:
-f | -force – Enables a user with a console (c) role to take the console from any current user and force that user into view mode.
-script – Bypasses the prompt for a yes or no confirmation.
When you reach the system console, you see the OpenBoot prompt (ok) unless Oracle Solaris is running.
