Go to main content
SPARC and Netra SPARC S7-2 Series Servers Administration Guide
Exit Print View
Updated: January 2017
Obtain the OpenBoot Prompt (Oracle ILOM CLI)
Use this procedure when the host is powered down and you are logged into Oracle ILOM.
  1. Log in to Oracle ILOM.
    See Log In to Oracle ILOM.
  2. Change the auto-boot? parameter to false.
    -> set /HOST/bootmode script=”setenv auto-boot? false”
    This command temporarily prevents the OS from booting before you obtain the OpenBoot prompt. This change applies only to a single reset and expires in 10 minutes if the power on the host is not reset.
  3. Reset the host.
    -> reset /System
  4. Switch communication to the host.
    -> start /HOST/console
    Are you sure you want to start /HOST/console (y/n)? y
    Serial console started. To stop, type #.
    The server might take several minutes to complete POST and then displays the OpenBoot prompt.
Related Information
