Go to main content
SPARC and Netra SPARC S7-2 Series Servers Administration Guide
Exit Print View
Updated: January 2017
Obtaining the OpenBoot Prompt
There are several ways to reach the OpenBoot prompt (ok).
Note - If you have any problems reaching the OpenBoot Prompt by your chosen method, refer to some alternatives in Obtain the OpenBoot Prompt Under Various Conditions.
Related Information
