OpenBoot Prompt
When the host is powered on but the OS is not booted, you
communicate with the OpenBoot firmware. OpenBoot firmware displays ok as
its prompt.
For more details about OpenBoot, refer to the OpenBoot 4.x Command Reference Manual at:
http://www.oracle.com/goto/openboot/docs
This table lists the common tasks that are performed at the ok prompt.
Boot the host. |
Configure OpenBoot parameters. |
Run diagnostics. |
Refer to the service manual for your server, detecting and managing faults. |
Reset and power off the host. |
At the OpenBoot prompt, type help reset to
display details about the reset command. |
Eject media. |
At the OpenBoot prompt, type help eject to
display details about the eject command. |
