Creating Head End Systems
The next step is to create a record for the head end system. This record defines processing methods for the head end system.
Note: Payload processing head end systems used with Oracle Utilities
Digitial Asset Cloud Service and Digital Asset Management are the customer information
systems from which measurement data will be received. For example, if your
implenentation is receiving measurement data from Oracle Utilities Customer to Meter,
you would create a "Customer to Meter" head end system.
Processing Methods for Payload Processing
The following processing methods should be configured to support payload processing:
- Initial Measurement Creation: defines the business object(s) and other data used to create initial measurements. When using Legacy Measurement Processing, the IMD Seeder business object uses this processing method to determine which type of initial measurement business object to instantiate when receiving usage from a head end system. When using Direct Measurement Processing, specify an IMD Type(s). See Direct Measurement Processing in the Business User Guide for more information.
If usage payload include time of use periods or service quantity identifiers, you should also configure SQI Translation and TOU Translation processing methods.
See Understanding Head End Systems and Understanding Processing Methods in the Administrative User Guide for more information about creating and configuring a head end system and its processing methods.
