1. Title Bar 2. User Menu 3. About Link 4. Help Link 5. File and Tools Menus | 6. Toolbar 7. Environment Information 8. System Status Indicator 9. Annunciators |
Menu Option | Submenu Option | Description | Toolbar Icon |
New | Switching Sheet... | Opens the New Switching Sheet tool that allows you to create a new switching sheet based on switching event type (for example, planned or emergency). | |
Safety Document... | Opens the New Safety Document tool that allows you to create a new safety document from a set of predefined types. | ||
Event... | Opens the Create Event tool that allows you to create a new outage, new stable outage, non-outage, or restored real outage event. | ||
Damage Assessment... | Opens a new Damage Assessment document window. See “Creating Fuzzy Damage Assessments” for information. | ||
Open | Switching Sheet... | Allows you to open a switching sheet. | |
Switching Sheet Search... | Allows you to search for a switching sheet. By default, the search field searches against the switching sheet number and description fields. See “Open Switching Sheet using Switching Sheet Search”. | -- | |
Safety Document... | Allows you to open a safety document. | ||
Safety Document Search... | Allows you to search for a safety document. By default, the search field searches against the safety document number and description fields. See “From the Web Workspace Search Safety Document Dialog”. | -- |
Work Agenda 1... | Opens the Work Agenda. See “Using the Work Agenda”. | ||
Work Agenda 2... | Opens a second Work Agenda. | ||
Viewer 1... | Opens the Viewer. See “Using the Viewer”. | ||
Viewer 2... | Opens a second Viewer. | ||
Authority... | Opens the Authority tool, which grants control authority to users subscribing to discrete operations zones. See “Taking Authority for Control Zones”. | -- | |
Crews... | Opens the Crew Actions tool, which shows the crews available in the subscribed control zone. See “Using Crew Actions”. | -- | |
User Log... | Opens the User Log, which displays a list of all single-user actions within a certain time period. See “Using the User Log”. | ||
Manage Documents... | Opens the Manage Documents window, which allows you to associate documents to objects. See “Associating Documents with Assets”. | ||
Switching Overlaps... | Opens the Global Overlaps tool. See “Viewing Global Overlaps”. | ||
Miscellaneous Log... | Opens the Miscellaneous Log. See “Using the Miscellaneous Log”. | ||
Condition Summaries... | Opens the Condition Summaries. Predefined filters include: • All Conditions • Notes • Pending Construction • Pending Decommission • Tags See “Condition Summaries” for details. | ||
SCADA Summary... | Displays the SCADA Summary. See “Using the SCADA Summary” for more information. | -- | |
SCADA Status... | Displays the SCADA Status window. | -- | |
Alarms Displays | Alarms... | Display all current alarms in the subscribed authority zones. See “Understanding the Alarms List” | -- |
Abnormal Alarms... | Display a list of off-nominal assets in the subscribed authority zones. See “Understanding the Abnormal Assets List”. | -- | |
Alarm History | Display the alarm history for the subscribed authority zones See “Understanding the Alarm History List”. | -- |
Menu Option | Description |
Web Workspace Help | Launches the online help system and loads the Web Workspace content. |
Calculate Network Latency... | Runs a network diagnostic utility and returns the results in the Network connectivity results window. |
Email Log Files... | Gathers the environment's log files and attaches them to a new email message using your default email client. The log files can then be sent to your support team or contact for further analysis. |
Set Debug... | Launches the Set Debug dialog box allowing you to set debug on or off within your current environment. This is used for debugging and analysis purposes. See “Setting Debug” for more information. |
About Web Workspace | Opens a window with environment and software information. |
