1 EMS Maintenance
This topic provides an overview of the maintenance required on the Electronic Messaging System.
Message Media Control Maintenance
The messages that are sent from and delivered to the bank are transmitted and received over sources that are external to Oracle FLEXCUBE Universal Banking. These external sources are called Media Control Systems (MCS).
In a distributed environment, the database of a branch is located in a node or server. The MCS of the messages is also installed in a node. Thus, while defining an MCS, also indicate the node in which it is installed.
An MCS can handle only one media, hence the user needs to set up several media control systems for the various media types maintained for the bank. Apart from indicating the media type for an MCS, the user can indicate separate directories from which Oracle FLEXCUBE Universal Banking should read and write incoming and outgoing messages for a given media.
The user can maintain MCS details in the Message Media Control Maintenance screen. The details that are specified in this screen control the medium of delivery and reception of messages. Refer to the topic unresolvable-reference.html#GUID-BBE6C2C8-D989-4919-98AC-DC04658B4D3C for detailed information.
Media Maintenance
Refer to the topic unresolvable-reference.html#GUID-4ED1738A-2759-4058-BE87-2715C22CB342 for detailed information.
Message Queues Mapping Maintenance
Refer to the topic unresolvable-reference.html#GUID-8F0E40E7-D112-41E9-99BC-84E917A1D35D for detailed information.
Message Queue Maintenance
Refer to the topic unresolvable-reference.html#GUID-E5AF87E0-E9BA-4AEE-8313-25A9B51710D9 for detailed information.
SWIFT Message Notification Browser
Refer to the topic unresolvable-reference.html#GUID-3FE21B1A-5C36-42DB-9499-70EF7184F73B for detailed information.
SWIFT Net Service Definition
SWIFT Local Authentication Maintenance
Mapping Rule Group
Defining Rule Group
Routing Rule Definition
Defining Protocol Parameter
File Transfer Adapter Connector Configuration
- Create an application base directory as per the path mentioned in the mstm_ems_system_parameters (APP_BASE_DIR).
- Create below folder structure in the application base directory:
- payload\EMS_OUT
- XSL
- In the XSL folder, copy all the XSL required for message transformation
Distinguished Name Definition
Defining Debulk Rule
Connectivity Operation Manager
Refer to the topic unresolvable-reference.html#GUID-43E8485C-DBC2-4A54-B7FB-64C9BCED3BD7 for detailed information.
Outbound File Browser
Refer to the topic unresolvable-reference.html#GUID-34625FB5-3EAD-4E61-99AA-5E924CE2E30B for detailed information.
Inbound File Browser
Refer to the topic unresolvable-reference.html#GUID-EB706E6B-2C95-47BF-8A9E-A217C11AFC37 for detailed information.
Defining Bulk Preference
Bulk Monitor
Refer to the topic unresolvable-reference.html#GUID-9D083061-5966-4E41-BA6C-B6BAAC477F59 for detailed information.
- Maintain Message Media Control
This topic explains systematic instructions to maintain message media control. - Maintain Message Media Details
This topic explains systematic instructions to maintain message media details. - Maintain Message Queue Mapping
This topic explains systematic instructions to maintain the mapping of Message Queues. - Maintain Message Queues
This topic explains systematic instructions to maintain message queues. - Process SWIFT Message Notification Browser
This topic explains systematic instructions to process the SWIFT message notification browser. - Maintain SWIFTNet Service Definition
This topic explains systematic instructions to maintain the SWIFTNet service definition. - Process SWIFT Net Service Definition Summary
This topic explains systemic instructions to process the SWIFT Net service definition summary. - Maintain SWIFT LAU Key
This topic explains systematic instructions to maintain the SWIFT LAU key. - Process SWIFT LAU Key Summary
This topic explains systematic instructions to process SWIFT LAU key maintenance details. - Process Outgoing SWIFT LAU
This topic describes the flowchart of the outgoing message SWIFT LAU. - Process Incoming SWIFT LAU
This topic describes the flowchart of the incoming message SWIFT LAU. - Maintain Rule Group Mapping
This topic explains systematic instructions to maintain the mapping of Rule Groups. - Process Rule Group Mapping Summary
This topic explains systematic instructions to process the rule group mapping summary screen. - Maintain Rule Group Definition
This topic explains systematic instructions to maintain the Rule Group definition. - Process Rule Group Definition Summary
This topic explains systematic instructions to process the rule group definition summary. - Maintain Routing Rule Definition
This topic explains systematic instructions to maintain the Routing Rule definition. - Process Routing Rule Definition Summary
This topic explains systematic instructions to process the routing rule definition summary. - Maintain Protocol Parameter Definition
This topic explains systematic instructions to maintain the protocol parameter definition. - Process Protocol Parameter Definition Summary
This topic explains systematic instructions to process protocol parameter definition summary. - Maintain File Transfer Adapter Connector Configuration
This topic explains systematic instructions to maintain the File Transfer Adapter Connector Configuration screen. - Process SWIFTNet FTA Connector Definition Summary
This topic explains systematic instructions to process the SWIFTNet FTA connector definition summary. - Process Distinguished Name Definition
This topic explains systematic instructions to process the distinguished name definition. - Process Distinguished Name Definition Summary
This topic explains systematic instructions to process the summary of distinguished name definitions. - Maintain De Bulk Rule Definition
This topic explains systematic instructions to maintain the De Bulk rule definition. - Process Debulk Rule Summary
This topic explains systematic instructions to process the summary of debulk rule. - Maintain Connectivity Operation Manager
This topic explains systematic instructions to maintain the connectivity operation manager. - Process Outbound File Browser
This topic explains systematic instructions to search and view the outbound files. - Process Inbound File Browser
This topic explains systematic instructions to process the summary of the inbound file browser. - Maintain Bulking Preference Definition
This topic explains systematic instructions to maintain the bulking preference definition. - Process Bulking Preference Definition Summary
This topic explains systematic instructions to process bulking preference definition summary. - Process Bulk Monitor Summary
This topic explains systematic instructions to process the summary of messages and executions in bulk.
