man pages section 3: Library Interfaces and Headers
Exit Print View
Updated: July 2014
fcntl(3HEAD)
Name
fcntl.h, fcntl - file control options
Synopsis
#include <fcntl.h>
Description
The <fcntl.h> header defines the following requests and arguments for use by the functions fcntl(2), open(2), and openat(2).
Values for cmd used by fcntl() (the following values are unique):
F_DUPFD
Duplicate file descriptor.
F_DUPFD_CLOEXEC
Duplicate file descriptor with the close-on-exec flag FD_CLOEXEC set.
F_DUP2FD
Similar to F_DUPFD, but always returns arg.
F_DUP2FD_CLOEXEC
Similar to F_DUP2FD, but with the close-on-exec flag FD_CLOEXEC set.
F_GETFD
Get file descriptor flags.
F_SETFD
Set file descriptor flags.
F_GETFL
Get file status flags.
F_SETFL
Set file status flags.
F_GETOWN
Get process or process group ID to receive SIGURG signals.
F_SETOWN
Set process or process group ID to receive SIGURG signals.
F_FREESP
Free storage space associated with a section of the ordinary file fildes.
F_ALLOCSP
Allocate space for a section of the ordinary file fildes.
F_ALLOCSP64
Equivalent to F_ALLOCSP, but takes a struct flock64 argument rather than a struct flock argument.
F_GETLK
Get record locking information.
F_GETLK64
Equivalent to F_GETLK, but takes a struct flock64 argument rather than a struct flock argument.
F_SETLK
Set record locking information.
F_SETLK64
Equivalent to F_SETLK, but takes a struct flock64 argument rather than a struct flock argument.
F_SETLKW
Set record locking information; wait if blocked.
F_SETLKW64
Equivalent to F_SETLKW, but takes a struct flock64 argument rather than a struct flock argument.
F_SHARE
Set share reservation.
F_UNSHARE
Remove share reservation.
File descriptor flags used for fcntl():
FD_CLOEXEC
Close the file descriptor upon execution of an exec function (see exec(2)).
Values for l_type used for record locking with fcntl() (the following values are unique):
F_RDLCK
Shared or read lock.
F_UNLCK
Unlock.
F_WRLCK
Exclusive or write lock.
Values for f_access used for share reservations with fcntl() (the following values are unique):
F_RDACC
Read-only share reservation.
F_WRACC
Write-only share reservation.
F_RWACC
Read and write share reservation.
Values for f_deny used for share reservations with fcntl() (the following values are unique):
F_COMPAT
Compatibility mode share reservation.
F_RDDNY
Deny other read access share reservations.
F_WRDNY
Deny other write access share reservations.
F_RWDNY
Deny other read or write access share reservations.
F_NODNY
Do not deny other read or write access share reservations.
File creation and assignment flags are used in the oflag argument by open() and openat(). All of these values are bitwise distinct:
O_CREAT
Create file if it does not exist.
O_EXCL
Exclusive use flag.
O_NOCTTY
Do not assign controlling tty.
O_TRUNC
Truncate flag.
O_TTY_INIT
Set terminal parameters to have conforming behavior.
O_XATTR
When opening a file, this flag affects the way in which relative paths are resolved by open() and openat(). With this flag set, the path argument is resolved as an extended attribute reference on either the current working directory (if open) or of the file referenced by the file descriptor argument of openat().
File status flags used for fcntl(), open(), and open():
O_APPEND
Set append mode.
O_NDELAY
Non-blocking mode.
O_NONBLOCK
Non-blocking mode (POSIX; see standards(5)).
O_DSYNC
Write I/O operations on the file descriptor complete as defined by synchronized I/O data integrity completion.
O_RSYNC
Read I/O operations on the file descriptor complete at the same level of integrity as specified by the O_DSYNC and O_SYNC flags. If both O_DSYNC and O_RSYNC are set in oflag, all I/O operations on the file descriptor complete as defined by synchronized I/O data integrity completion. If both O_SYNC and O_RSYNC are set in oflag, all I/O operations on the file descriptor complete as defined by synchronized I/O file integrity completion.
O_SYNC
When opening a regular file, this flag affects subsequent writes. If set, each write(2) will wait for both the file data and file status to be physically updated. Write I/O operations on the file descriptor complete as defined by synchronized I/O file integrity completion.
Mask for use with file access modes:
O_ACCMODE
Mask for file access modes.
File access modes used for fcntl(), open(), and openat():
O_EXEC
Open ordinary file for execute only.
O_RDONLY
Open for reading only.
O_RDWR
Open for reading and writing.
O_SEARCH
Open directory for search only.
O_WRONLY
Open for writing only.
The following constants are used by system calls capable of resolving paths relative to a provided open file descriptor:
AT_FDCWD
Special value to pass in place of a file descriptor to inform the called routine that relative path arguments should be resolved from the current working directory.
The following constant is a value to be used for the flag passed to faccessat():
AT_EACCESS
Check access using effective user and group ID.
The following constant is a value to be used for the flag passed to fstatat(), fchmodat(), fchownat(), and utimensat():
AT_SYMLINK_NOFOLLOW
Do not follow symbolic links. In this case the functions operate on the symbolic link file rather than the file the link references.
The following constant is a value to be used for the flag passed to linkat():
AT_SYMLINK_FOLLOW
Follow symbolic link.
The following constants are values to be used for the oflag passed to open() and openat():
O_CLOEXEC
Set the FD_CLOEXEC flag on the new file descriptor.
O_DIRECTORY
Fail if not a directory.
O_NOFOLLOW
The following constant is a value to be used for the flag passed to unlinkat():
AT_REMOVEDIR
Remove directory instead of file.
The flock structure describes a file lock. It includes the following members:
short   l_type;   /* Type of lock */
short   l_whence; /* Flag for starting offset */
off_t   l_start;  /* Relative offset in bytes */
off_t   l_len;    /* Size; if 0 then until EOF */
long    l_sysid;  /* Returned with F_GETLK */
pid_t   l_pid;    /* Returned with F_GETLK */
The structure fshare describes a file share reservation. It includes the following members:
short   f_access; /* Type of reservation */
short   f_deny;   /* Type of reservations to deny */
long    f_id;     /* Process unique identifier */
Attributes
ATTRIBUTE TYPE
ATTRIBUTE VALUE
Interface Stability
Committed
Standard
See also
creat(2), exec(2), fcntl(2), open(2), fdatasync(3C), fsync(3C), fsattr(5), attributes(5), standards(5)
Notes
Data is successfully transferred for a write operation to a regular file when the system ensures that all data written is readable on any subsequent open of the file (even one that follows a system or power failure) in the absence of a failure of the physical storage medium.
Data is successfully transferred for a read operation when an image of the data on the physical storage medium is available to the requesting process.
Synchronized I/O data integrity completion (see fdatasync(3C)):
  • For reads, the operation has been completed or diagnosed if unsuccessful. The read is complete only when an image of the data has been successfully transferred to the requesting process. If there were any pending write requests affecting the data to be read at the time that the synchronized read operation was requested, these write requests will be successfully transferred prior to reading the data.
  • For writes, the operation has been completed or diagnosed if unsuccessful. The write is complete only when the data specified in the write request is successfully transferred, and all file system information required to retrieve the data is successfully transferred.
File attributes that are not necessary for data retrieval (access time, modification time, status change time) need not be successfully transferred prior to returning to the calling process.
Synchronized I/O file integrity completion (see fsync(3C)):
  • Identical to a synchronized I/O data integrity completion with the addition that all file attributes relative to the I/O operation (including access time, modification time, status change time) will be successfully transferred prior to returning to the calling process.
