man pages section 3: Library Interfaces and Headers
Exit Print View
Updated: July 2014
semaphore(3HEAD)
Name
semaphore.h, semaphore - semaphores
Synopsis
#include <semaphore.h>
Description
The <semaphore.h> header defines the sem_t type, used in performing semaphore operations. The semaphore can be implemented using a file descriptor, in which case applications are able to open up at least a total of {OPEN_MAX} files and semaphores. The symbol SEM_FAILED is defined (see sem_open(3C)).
Inclusion of the <semaphore.h> header can make visible symbols defined in the headers <fcntl.h> and <sys/types.h>. See fcntl.h(3HEAD) and types.h(3HEAD).
Attributes
ATTRIBUTE TYPE
ATTRIBUTE VALUE
Interface Stability
Committed
Standard
See also
fcntl.h(3HEAD), types.h(3HEAD), sem_destroy(3C), sem_getvalue (3C), sem_init(3C), sem_open (3C), sem_post(3C), sem_timedwait (3C), sem_unlink(3C), sem_wait (3C), attributes(5), standards (5)
