man pages section 3: Library Interfaces and Headers
Exit Print View
Updated: July 2014
uio.h(3HEAD)
Name
uio.h, uio - definitions for vector I/O operations
Synopsis
#include <sys/uio.h>
Description
The <sys/uio.h> header defines the iovec structure, which includes the following members:
void   *iov_base     /* base address of a memory region
                        for input or output */
size_t iov_len       /* size of the memory pointed to by
                        iov_base */
The <sys/uio.h> header uses the iovec structure for scatter/gather I/O.
The ssize_t and size_t types are defined as described in <sys/types.h>.
Usage
The symbol {IOV_MAX} defined in <limits.h> should always be used to learn about the limits on the number of scatter/gather elements that can be processed in one call, instead of assuming a fixed value.
Attributes
ATTRIBUTE TYPE
ATTRIBUTE VALUE
Interface Stability
Committed
Standard
See also
read(2), write(2), limits.h(3HEAD), types.h(3HEAD), attributes(5), standards(5)
