man pages section 3: Library Interfaces and Headers
Exit Print View
Updated: July 2014
mqueue.h(3HEAD)
Name
mqueue.h, mqueue - message queues
Synopsis
#include <mqueue.h>
Description
The mqueue.h header defines the mqd_t type, which is used for message queue descriptors. This will not be an array type. A message queue descriptor may be implemented using a file descriptor, in which case applications can open up to at least OPEN_MAX file and message queues.
The mqueue.h header defines the sigevent structure (as described in <signal.h>, see signal.h(3HEAD)) and the mq_attr structure, which is used in getting and setting the attributes of a message queue. Attributes are initially set when the message queue is created. A mq_attr structure has the following members:
long    mq_flags       message queue flags
long    mq_maxmsg      maximum number of messages
long    mq_msgsize     maximum message size
long    mq_curmsgs     number of messages currently queued
Inclusion of the mqueue.h header may make visible symbols defined in the headers fcntl.h, signal.h, sys/types.h, and time.h.
Attributes
ATTRIBUTE TYPE
ATTRIBUTE VALUE
Interface Stability
Committed
Standard
See also
fcntl.h(3HEAD), signal.h(3HEAD), time.h(3HEAD), types.h(3HEAD), attributes(5), standards(5)
