man pages section 3: Library Interfaces and Headers
Exit Print View
Updated: July 2014
fnmatch.h(3HEAD)
Name
fnmatch.h, fnmatch - filename-matching types
Synopsis
#include <fnmatch.h>
Description
The fnmatch.h header defines the following constants:
FNM_NOMATCH
The string does not match the specified pattern.
FNM_PATHNAME
Slash in string only matches slash in pattern.
FNM_FILE_NAME
An alias of FNM_PATHNAME.
FNM_PERIOD
Leading period in string must be exactly matched by period in pattern.
FNM_NOESCAPE
Disable backslash escaping.
FNM_IGNORECASE
Ignore case when making comparisons.
FNM_CASEFOLD
An alias of FNM_IGNORECASE.
FNM_LEADING_DIR
Match pattern as leading directory path.
FNM_NOSYS
Reserved.
Attributes
ATTRIBUTE TYPE
ATTRIBUTE VALUE
Interface Stability
Committed
Standard
See also
fnmatch(3C), attributes(5) , standards(5)
