man pages section 3: Library Interfaces and Headers
Exit Print View
Updated: July 2014
inet.h(3HEAD)
Name
inet.h, inet - definitions for internet operations
Synopsis
#include <arpa/inet.h>
Description
The <arpa/inet.h> header defines the type in_port_t, the type in_addr_t, and the in_addr structure, as described in in.h(3HEAD).
Inclusion of the <arpa/inet.h> header may also make visible all symbols from in.h(3HEAD).
The following are declared as functions, and may also be defined as macros:
in_addr_t       inet_addr(const char *);
in_addr_t       inet_lnaof(struct in_addr);
struct in_addr  inet_makeaddr(in_addr_t, in_addr_t);
in_addr_t       inet_netof(struct in_addr);
in_addr_t       inet_network(const char *);
char            *inet_ntoa(struct in_addr);
Default
For applications that do not require standard-conforming behavior (those that use the socket interfaces described in section 3N of the reference manual; see Intro(3) and standards(5)), the following may be declared as functions, or defined as macros, or both:
uint32_t    htonl(uint32_t);
uint16_t    htons(uint16_t);
uint32_t    ntohl(uint32_t);
uint16_t    ntohs(uint16_t);
Standard conforming
For applications that require standard-conforming behavior (those that use the socket interfaces described in section 3XN of the reference manual; see Intro(3) and standards(5)), the following may be declared as functions, or defined as macros, or both:
in_addr_t    htonl(in_addr_t);
in_port_t    htons(in_port_t);
in_addr_t    ntohl(in_addr_t);
in_port_t    ntohs(in_port_t);
Attributes
ATTRIBUTE TYPE
ATTRIBUTE VALUE
Interface Stability
Committed
Standard
See also
Intro(3), htonl(3SOCKET), htonl(3XNET), inet_addr(3SOCKET), inet_addr(3XNET), in.h(3HEAD), attributes(5), standards(5)
