man pages section 3: Library Interfaces and Headers
Exit Print View
Updated: July 2014
utmpx(3HEAD)
Name
utmpx.h, utmpx - user accounting database definitions
Synopsis
#include <utmpx.h>
Description
The utmpx.h header defines the utmpx structure, which includes the following members:
char                  ut_user[];  /* user login name */
char                  ut_id[];    /* unspecified initialization */
                                  /* process identifier */
char                  ut_line[];  /* device name */
pid_t                 ut_pid;     /* process ID */
short                 ut_type;    /* type of entry */
for X/Open compilation environments:
struct ut_exit_status ut_exit; /* process termination/exit status*/
for all other compilation environments:
struct exit_status    ut_exit;    /* process termination/exit status*/
struct timeval        ut_tv;      /* time entry was made */
int                   ut_session; /* session ID, used for windowing */
short                 ut_syslen;  /* significant length of ut_host */
                                  /* including terminating null */
char                  ut_host[];  /* remote host name */
The pid_t type is defined through typedef as described in sys/types.h.
The timeval structure is defined as described in sys/time.h.
Inclusion of the utmpx.h header can also make visible all symbols from sys/time.h.
The following symbolic constants are defined as possible values for the ut_type member of the utmpx structure:
EMPTY
No valid user accounting information.
BOOT_TIME
Identifies time of system boot.
OLD_TIME
Identifies time when system clock changed.
NEW_TIME
Identifies time after system clock changed.
USER_PROCESS
Identifies a process.
INIT_PROCESS
Identifies a process spawned by the init process.
LOGIN_PROCESS
Identifies the session leader of a logged-in user.
DEAD_PROCESS
Identifies a session leader who has exited.
Attributes
ATTRIBUTE TYPE
ATTRIBUTE VALUE
Interface Stability
Committed
Standard
See also
endutxent(3C), time.h(3HEAD), types.h(3HEAD), attributes(5) , standards(5)
